Support our host
News
Software
Reference
Community
Parts Library
About Us
Library
Published By Holly-Wood on Wednesday, August 22, 2007 - 03:17 PM
Printer-friendly page
The chart lists brick shapes we've got from the LEGO Universe Team. They need some clean-up to be suitable for the LDraw Parts Tracker. If you wanna contribute just download the file you want work on, but don't forget to email the LDraw Administration Team telling the part number your working on - your name will be associated with the part in order to avoid overlap.
Special attention has to be paid to:
  • New header specs.
  • BFC
  • Category
  • Keywords
  • Color correction
  • Additional primitive substitution where needed
  • Stud orientation
  • Separation into subfiles where needed
  • Grouping into code sections
  • Origin in sync with the LDraw standard
Please use the following guideline for the ownership:
0 PartDescription
0 Name: Filename.dat
0 Author: RealName [UserName]
0 !HISTORY YYY-MM-DD {The LEGO Universe Team} Original part shape
0 !HISTORY YYYY-MM-DD [UserName] File preparation for LDraw Parts Tracker
Please use the !HISTORY date from the chart for the LEGO Universe history line.
The parts description has been taken from Peeron.com. Please check back with the PT Admins if your part has no description or you feel that the description is not appropriate. Please understand also that only authors who have affirmed the LDraw Contributor Agreement are allowed to fix these parts. Once the part has been submitted to the Parts Tracker, any reviewer finding errors may fix them immediately and re-submit the fix without asking permission, since the original author is the LEGO Universe Team.
History
date
Number Already
at PT?
Name (taken from Peeron.com) Cleaner
2008-12-20 2543.dat No Minifig Hat Rag - (Peeron number x70)
2008-12-20 30168.dat No Minifig Mummy Headdress - (Peeron number x177)
2008-12-20 30177.dat No Minifig Ninja Wrap - (Peeron number x54)
2008-12-20 30276.dat No Minifig Headdress Jungle
2008-12-20 30325.dat No Minifig Accessory Helmet Mining
2008-12-20 30608.dat No Minifig Hair Flat Top
2007-08-25 3278.dat Official
part 70
Tap 1 x 2 Spout
2007-08-25 33129.dat No Boat 8 x 18 x 2 & 1/3
2007-08-25 3496.dat Official
part 69
Tap 1 x 2 Base
2007-08-25 40001.dat No Technic Steering Yoke (Peeron number - x576)
2007-08-25 40241.dat No Door 1 x 4 x 6 with Window
2007-08-25 41890.dat No Minifig Mechanical Arm Advanced - (Peeron number - x387)
2008-12-20 43894.dat No Minifig Hat Mongolian
2007-08-25 47406.dat No Cockpit 6 x 10 x 2 Curved
2007-08-25 47976.dat No Brick 12 x 12 with Holes on Two Sides and Vertical Pegs in Corners
2007-08-25 48005.dat No Boat Mast 4 x 4 x 21
2008-12-20 54090.dat No Cockpit 8 x 16 x 2 Curved
2008-12-20 54091.dat No Slope Brick Round 8 x 8 Double Inverted
2008-12-20 54095.dat No Slope Brick Round 8 x 8 Double
2007-08-25 57467.dat Official
part 38
Minifig Harpoon
2007-08-25 58827.dat No Support 2 x 2 x 10 Girder Triangular with Axlehole
2008-12-20 6158.dat No Minifig Fire Helmet Breathing Hose - (Peeron number x171)
Recipient 2011
Travis Cobbs
There are 43 unlogged users and 0 registered users online.
 Log in Problems?
 New User? Sign Up!
